If a relay switch that powers 2 sets of plug sockets sudenely trips and wont flip back up, what could be causing it to not stay up? (no jokes about it 'not staying up' please).
Not being an electrician im not sure how they work exactly, but since it cant be fliped back up im gusesing whatever caused the relay to trip in the first place is still causing it to be triped when the relay is turned back on.
One plug socket was compleatly empty when this happened, the other socket had a pc (powered off), laptop (powered off), a cable modem, and a router all pluged into it. I daubt any of these caused the fault because when plugged into a switch on a seperate relay, they work fine without causing the other relay to trip.
With NOTHING pluged into any of the wall sockets that are connected to the tripped relay, the relay still refuses to be turned back on, does this mean the problem lies with either a) the relay itself being faulty, or b) a problem with the wall socket wiring causing power to be set to ground, thus tripping the relay, or c) something else?
