trackrat said:I am a retired electrician and some of the advice given to you would frighten me.
Yes you can do your own plumbing, as all water can do is drown you and you can see it coming.
Electricity you cant see but it can be deadly if you get it wrong.
In a bedroom you do not normally have that many sockets so a 16a mcb will suffice, in the main room you tend to have not only sockets on the ring main but spurs of them as well, so a 32amcb is normal.
First off, based on this thread, I am not going to now decide to rewire my house single-handedly or start randomly switching MCBs. In fact, I may never even tamper with them, if after all my electric items have arrived and are working fine. However, its just nice to know how things work and what I might try doing should things not work out. In fact, its quite possible that if the MCB keeps tripping, then I may well just get a leccy in.
If someone on this thread says, "if you slice your wrists with razorblade, you will bleed to death", it does not mean that we will see people start to test the theory out. This is just a forum. Thats all it is, where we discuss things, which may not even be true. It is upto the reader to use common sense.
trackrat said:Electricity you cant see but it can be deadly if you get it wrong.
In the main room, I have 6 double sockets + 1 spur.
In the bedroom, I have 6 double sockets.
I watched as the wires (for the sockets) were slid into walls, etc. The wires, in the walls were not insulated in any extra material. The only thing insulating the wires are their own rubber membrane and a few cms of cement/plaster.
I intend to have a lot of electric gadgets and rather than use 6 in 1 plug in sockets, I would rather plug directly into the socket.
