- 18 Oct 2002
- Stone, Staffordshire
T'other night I switched on the lights on the extractor hood only to be met with a bright flash of light, a pop and then nothing.
I checked the extractor function and that didn't work in any speed 1-2-3.
There is a fused switch on the wall which I guess must be for the extractor so I popped out the fuse and tested that. The fuse was dead so I replaced it with a new fuse but alas I still have no light or extraction!
Is there likely to be an internal fuse in there as well somewhere? Obviously something made it go bang (my term for the flashing light) so I just want to know whether it's dead Jim and I need to find a new extractor or I can buy part x or replace fuse Z and all will be good again!
The exctractor is a whirlpool generation 2000+
