- 8 Jan 2004
Without phisically cutting the cables I can't see how they can stop you using power?
Pull the cablehead fuse?
I bought a repossessed house recently where all the utilities we're disconnected. All I did was turn the main stopcock, the valve on the mains gas inlet and switch the electricity on at the main consumer unit and everything was working again. The previous owners we're with e.on, but we're now with edf. Without phisically cutting the cables I can't see how they can stop you using power?
That is a automatic code 1/2 (can't remember which) and should be an unsatisfactory certificate. You can not use the mains water pipe from a supplier as a earth!. Also there should be a earth on the gas supply.
I'm guessing it is a TT system. If that comes back as satisfactory without the earth rod being installed id be amazed
Do you know if the property is fitted with a RCD?
EDF confirmed that MeterPlus/nPower would be out to my house between 15:00 and 22:00
I phone EDF at 16:30
19:00 when I ring EDF again
19:55 and I ring EDF again
21:15 rolls around and I call their emergency helpline
As much as I feel for the situation you are in....
Impatient much?
Err it looks like he was right to try and phone them and confirm they were going to arrive, which they didn't. I'd be pretty impatient with a company that had treated me in the way he has been treated and the eventual outcome shows his concern was valid.
)I bought a repossessed house recently where all the utilities we're disconnected. All I did was turn the main stopcock, the valve on the mains gas inlet and switch the electricity on at the main consumer unit and everything was working again. The previous owners we're with e.on, but we're now with edf. Without phisically cutting the cables I can't see how they can stop you using power?
