I can't seem to get my new monitor (link below) to run at the advertised 95Hz. It won't go above 60Hz at any resolution (tired 1080p as well and it's not working).
I have an R9 290 which I understand supports DP 1.2 (which means it should support 1440p 95Hz surely?). I have tried both DP and HMDMI cables.
The option for 95Hz is shown in display properties but when applied the screen flickers or turns black before reverting back to 60Hz. It shows up as a Generic Pnp Monitor in control panel, but it registers as a freesync compatible monitor in the AMD control panel. I'm a bit stumped here tbh, does anybody have experience dealing with this sort of problem?
https://www.electriq.co.uk/p/eiq-27mq95fshdru/electriq-eiq27mq95fshdru-monitor
