The mrs and I just had one of those "I told you I wanted it done this way" conversations which never took place. We are a few weeks from getting the conservatory floor done so trying to work out where to run cables etc.
The setup in the conservatory is as follows:
The power comes from a spur off a double socket in the house to the conservatory via a fused socket (with switch). This then goes to a double socket which is then spurred off to another socket on the far side of the room.
I'd like to add a single socket on the wall where the purple X is for a TV.
I have read conflicting ideas of how to achieve this. One idea is that I can add as many spurs as I want as there is a 13A fuse to protect the circuit.
How would you guys go about this?
. As mentioned above, make sure from a wiring perspective the new socket is after the FCU.
