Electronics help... DC adaptors....
18 Oct 2002
Maidenhead
Hi all,
Ive got a VGA box today, but its got a non uk plug on the adaptor (two flat prongs). On the adaptor it says
Switching Power Supply
Model: STC3.0-06
Input AC100-240V 50-60hz
Output DC5V 800MA
On the actual device it says DC5V...
now ive got a uk adaptor which fits, and says
DVE
Model DSA - 0151A-05 A
Input 200-240V 50/60hz 0.4A
Output +5V 2.4A
and they've both got the same kind of symbol on them like this
Will this work? or am I going to blow it up?
fornowagain said:
Yeah it's called positive tip. Make sure the ID/OD of the plug & socket are the same and the PSU you have is over rated. So you should be good to go.
the what? ID/OD?? sorry I know nothing about electronics!
Jokester said:
Inner and Outer Diameter I would imagine.
Jokester
ahh i see. They appear to be the same.. The only thing is the metal connector on the new one is a bit shorter than the original. Would that matter?
Then try it for fit before powering up then check again that the polarity diagrams (Your last pic in the original post) are identical then power up and pray :eek:
Seriously, as long as the fit and polarity are ok you can't go wrong. Your substitute PSU has 3 times the power (current is 2.4 Amps against .8 Amps) of the original at the same voltage (5v) which means it will easily run your equipment.
