ELM 327 MINI (Blue) ODBII - Bluetooth Diagnostics - that works with Car Scanner Android app
1 Dec 2004
S.Wales
Hi all,
I need to read some diagnostic codes on my BMW 120D - e82 (coup) - I used to have a chinese C110 code reader that worked well, however after about 5 years it broke
Anyway, i looked up online and people were reccomending buying a ELM 327 ODBII bluetooth adaptor to stick in the port in the car and use something like carscanner free (which i have on my android)
Anyway, paid £6 for the bluetooth reader, IE this one
which i know is a clone but it seems to connect ok to my car
the issue is, when i scan for troublecodes, car scanner is finding nothing,
1) I know the bluetooth adaptor is working as its streaming live data like acceleration, RPM info etc,
but the app is not finding any trouble codes
I know my car would have a number of things that needs to be read, one which i know should be showing is im getting the ABS light come on every time i drive
One of the reviews online with this adaptor said he was able to read all trouble codes on the car and picked up his ABS issues
ANyone used this adaptor before and the app car scanner for android before?
Is there any other apps i can try for free that people reccomend to see if it would pick up any codes? i need to find out which wheel may have a dodgy ABS speed sensor
I've been using this one* https://www.amazon.co.uk/gp/product/B07MBKZKRQ which is probably basically the same thing, along with Torque Pro and it finds a lot of codes/details the other apps including Car Scanner don't, but these dongles generally aren't as good as the professional tools - I've also got a handheld stand alone scanner which is better again than using the dongle with Torque (I keep one of the dongles in each of my vehicles just in case it might be useful).
* They were cheaper when I bought.
1) I know the bluetooth adaptor is working as its streaming live data like acceleration, RPM info etc, but the app is not finding any trouble codes
The issue with the cheap adapters and cheap/free apps is they don't either don't or can't scan all of the different modules within a car these days.
When OBD2 first came out, it was essentially just talking to the ECU (Engine Control Unit), but these days cars have control units for everything (including your ABS, but even as "simple" things as the Stereo), all connected together over essentially a network around your car.
Most of these other Control Units don't necessarily speak the same "language" (or protocol), so you can end up needing vehicle specific adapters in some cases.
For BMWs you are best with an appropriate adapter from this list, although you need to make sure it's the right one for your BMW series:
You can then use the paid for apps from that manufacturer https://www.bimmerlink.app/ or even your free apps may be able to see more control units.
Carista is another option, either with their adapter, or with one of the Bimmercode supported ones, and then just sign up to Carista for a month.
All i really care about for the moment is trying to find which wheel the ABS sensor is erroring on,
I am thinking its one of the rear, but i cant be sure, i am due to change the pads on the rear of my car, so i may just buy 2 x speed sensors and swap them out as i am changing the pads, if i decide to do it myself, i have replaced a speed sensor before but i wouldnt be able to change the reluctor ring.
As for the reader, i will try again with car scanner and ill see if i can download a couple more apps to see if i can get it to spit out some codes, if not i may see if i can pick up another reader or see if i can find the reader i had before which was pretty good (C110) or one of the newer versions, ill probably have to pay £20-£30 for one though
I was hoping to find a reader i could use across different car makes/models though as i am looking around for another car at the moment, and the reader would have been ideal to maybe take along if i am going to view a car
P.S i dont need inpa and a laptop, i dont need that in depth,
Give Carista a go with your existing adapter - it's £9.99 for one month, or it may even have a trial period (I seem to think it did if you signed up for a subscription, but you can cancel it before it starts)
Ill see if i can find it, if it has a trial period that will be enough to have a quick check,
thanks
ill also see if i can find torque pro
I dont mind paying £5 or £9 for one month, aslong as it finds codes!
Carista won't connect to this odbii Bluetooth adaptor
I have tried odb android
Tor odb2 diagnostics
These can see data but don't show any trouble codes
Spent about 45 mins out there in the car trying a few different apps. No trouble codes found
Not really liking the Bluetooth and the app side of diagnostic fault finding .
I did try and download what looked like an apk of an old version of torque pro . It had a rev counter which was working and could stream live data. But.again any scanning no codes what so ever
Surprised Torque Pro didn't find something, assuming there is anything to find, even when a proper handheld tool or specialised laptop diagnostics finds more detailed information it usually still at least finds something.
If you have this elm Bluetooth adaptor can you it with a Windows laptop programme if the laptop has a Bluetooth adaptor
Which app on the laptop ?
Just ordered to rear brake pads, brake pad wear sensor and a rear left or right abs sensor off ebay
Going to see if I can quickly Jack it up this eve to see if I may be find which one by visually looking.
It's going to one of the rear I recon either driver or passenger side
Parts wont arrive till mid next week prob so today will be inspect
Ok so managed to download carscanner again on the Android and it worked.. I chose N47 BMW profile. Seems to scan a lot of codes and it picked up the abs code
DTC 49F2 BMW
49F2) is a vehicle speed error from the engine management; if it cant tell how fast you're going, or if you've lost traction altogether, it struggles to sort out the fuelling etc. Again, speed related to rings or sensors
Not really telling if it's the sensor or the ring ..
I did manage to get one wheel off this evening and unscrewed the speed sensor. It didn't look like it has been forcefully dunning against something. But was abit dusty..I sprayed some wd40 on it and wiped it over with tissue and put back in screwed back in . This was the drivers side rear
I was going to check the passenger side rear but my bloody driveway i can't get proper ground clearance to jack up the wheel even with a brick so need to sort that out.
I guess if I manage to get it jacked up I can possibly replace the passenger side rear abs sensor after checking it . If it doesn't work try the new on on the right?
Google suggest the fault code is N/S/R
Hi all
Thread revival sorry.
I have been using the carscanner app which is working ok with the elm.
Is there any free or cheap apps that will gaurentee give me more data on identifying which corner is having a problem speed wise ?
I am not getting a speed code which usually starts 50x and tells you which corner on which axle. I am getting an
Now I have tried a few things including replacing the sensor on rear left with a new one. Taking the one in rear left putting. It in rear right .trying the washer trick behind the sensor which made it worse. Removed washer. Now could be reluctor rings but need a decent app that will show specific wheel speed on each corner through live data when your driving.
Carscanner has lots of live graphs. Boost. Torque. Fuel lots and lots and lots more .I cannot however see one though for wheel speed and per corner wheel speed from the wheel speed sensors..
Usually if you have this you can pinpoint which corner has the dodgy reading off the reluctor ring if it is.that
Any know apps which will provide this ?
Thanks
