- 13 Nov 2007
- Aberdeen
My first time ever. Got all the bits and bobs. First alteration and everything went fine. No blow ups! Temps all cool.
The guide says to:
1. Increase the FSB by 5MHz.
2. Reduce the multiplier and RAM divider if requried so that both are at stock speeds or slightly less.
Now:
On my machine I have:
system memory multiplier (spd) (set to auto) with various options ranging from auto and 4.0-2.0
CPU host Frequency (Mhz) 200
CPU clock ratio 10x.
memory frequency (Mhz) 800 800
On changing the CPU frequency to 205mhz the memory frequency goes from 800 800 to 800 820.
My questions are:
1) Is what I am changing what is listed in the guide. I don't want to be tweaking the wrong things!
2) When I try and reduce the system memory multiplier the options vary wildly between 800 420 (on 2.00) or 800 840 (on 4.0 or auto). I can't get them the same speeds.
Thanks
The guide says to:
Now:
My questions are:
Thanks
just in case
