perplex said:Hi. How do you work out confidence intervals? Is it x ± Z*sd ?![]()
Thanks.
You're welcomeperplex said:Thanks.
Digital Punk said:I'm confident the answers 42.
Seft said:95% CI is +-1.96*SD/root(n)
Not sure what Z value you need for a 99% CI. Check a table for the normal distribution.
Incidentally, it's emergency stats help...
