Hi All,
I need to move house, and I hope you can advise me what to do with my PC rig to transport it safely.
Loop is made of EK fittings and EK CPU block for Intel i9-7900X and it has as a part of it EVGA Hydro Copper 1080 Ti.
So the details of the travel are:
Now the question is:
Will the dry loop gets air inside for a few days don't get corroded?
I am a little bit in a catch 22
I don't want to risk a leak, but I don't want my loop to get corrosion inside.
Any advice will be appreciated.
Regards
Adam
- PC will move between the two countries (long journey and a good few bumps in the car),
- PC will be laying on the side of it,
- the reservoir is closed and sealed (EK pump/reservoir combo), but to avoid the leak, I am planning to drain it the whole loop
- the loop may stay dry-ish for a few days before I will refill it.
Regards
Adam
