- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
I have tested the new Enermax Apollish fans in my system.
I currently have a 800D with a single GTX480 and my CPU is sat under neath an H50.
I thought I would test the results of 3 x Enermax Apollish fans sat at the top of the case where Corsair kindly pre-cut 3 120mm holes.
Here are my result of my CPU temp using Prime95 with no fans in my case.
And the same results with my fans fitted
As for the LED brightness, they are great. My Corsair case was boring and dull, now however.
All in all, I think that these fans are a great buy and gives good CPU temp drops even when not using an air cooler. I imagine that using an air cooler wold yeild even bigger temp drops.
