As above really chaps.
In gear or out, whenever I touch the clutch (even slightly) the noise goes until pedal is released and then the noise continues.
Is it Clutch bearing?
Certainly sounds like it
I'd imagine the cost could be between 20k and £250 depending which car you own.
Ok thanks guys, the thing is I had a clutch replacement under warranty like 18 months ago, have done like 16k since then.
Was it a full clutch kit fitted? ie clutch plate, cover and release bearing?
