8 Jun 2013 at 15:26 #1 Amp34 Amp34 Caporegime Joined 25 Jul 2005 Posts 28,851 Location Canada I'm assuming these are all the same thing on a standard VW car? I just need to put in the VIN number? Thanks
8 Jun 2013 at 16:41 #2 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,508 Location Leafy Cheshire Chassis and VIN, yes. Engine number is different.
8 Jun 2013 at 17:27 #3 Amp34 Amp34 Caporegime OP Joined 25 Jul 2005 Posts 28,851 Location Canada Thanks. Whereabouts would you usually find the engine number?
8 Jun 2013 at 18:31 #5 ~Divine~Wind~ ~Divine~Wind~ Can't type for toffee Don Joined 14 Jun 2004 Posts 17,561 Location Newcastle U/T If you phone VW and provide them your reg/VIN then they may be able to provide your engine code. Are you needing to replace a part?
8 Jun 2013 at 20:24 #6 413x 413x Caporegime Joined 13 Jan 2010 Posts 33,471 Location Llaneirwg PMKeates said: On the engine Click to expand... I loled
