Hi
My friend bought his car round today (Ford Fiesta X reg) and i pointed out that his engine oil level was low.
The only engine oil i had in my garage is Castrol GTX Magnatec 10W-40. In the Fiesta handbook it states that it is recommended to use 5W-30 engine oil.
My friend topped up engine oil with the 10W-40 Castrol stuff and said it should be fine. It even says on the bottle 'recommended for modern engines' and his car is fairly modern.
Will his car be ok?
I have always been under the impression that you can't use different grade engine oil in the same engine. I assumed his car had already had 5W-30 in it so surely topping it up with 10W-40 is a bad idea, isnt it?
Thanks
Will his car be ok?
Thanks
