Engine Rebuild Pics!!!
18 Oct 2002
2 doors down from Subo
Almost finished my entire engine rebuild on the mr2. :D
Just got clutch, gearbox, some more polishing and some wiring to do and thats me!
-JE 86.5mm oversize pistons
-Greddy TD06 20g Turbo
-Greddy Intercooler
-540cc injectors
-1mm mls headgasket
-Lightened and balanced crank and rods
-Apexi PowerFC
400bhp here I come! :D
17 Mar 2006
Coventry
Mmm nice, are they high compression pistons or have u had the head skimmed. Havnt you cammed or ported, or is that soon to be done. but looks like your doing a good job, post some vids when its done!
OP
18 Oct 2002
The head has been skimmed. When I can afford it I'm getting a rev3 head and getting work done to it. But tbh, if I hit 400bhp and it's gonna be reliable I doubt I'll do anything else to it! :D
1 Feb 2003
Kent
are the 540's going to give you enough fuel?
one of my mates fitted a PE1919t and at 1.2bar he was out of fuel at 5000rpm - had to go with 800's.
not sure how the PE1919 compares to the TD06 20g though ;)
OP
18 Oct 2002
540cc's max out at 430 flywheel horse power approx. So if thats the case I'm not worried as thats more than enough! I don't think I'll need to upgrade tho as there are quite a few other guys running the same setup without any problems.
Matt82 said:
can i ask why it had to be rebuilt?
Long story but I had an "ex-friend" map the car using his ears as detcans and no wideband which resulted in a melted piston. So I decided to go all out this time :)
Caporegime
21 Oct 2002
Here
Doh,
what was he using? His toes on the engine?
