I have a PCI-E 1x SATA RAID card in. And I'm thinking of doing a hard drive upgrade.
I run a 150GB Raptor as my main drive, and this will remain as it is. I don't want RAID on the boot drive.
However, a huge bottleneck on the PC is hard drive access when it's working with huge (GBs in size) files.
So I wouldn't mind having RAID0 on the new drives.
I'm thinking 2 TB should be enough, so I'm looking at 2 of the new 1TB Hitachi drives.
Will the bandwidth on a PCI-E 1x card be enough to handle RAID0 on two of these?
Previously I've had problems with corruption in RAID using nForce4, so I don't want to use the RAID on the motherboard, in addition as long as I keep the card then it doesn't matter if I upgrade the motherboard, the array will stay in tact.
