Just finished building my new rig but having some problems. Its all fine until i try to run a game then it just falls over and reboots.
The system is.
3x Maxtor 6L300S0 DiamondMax 10 300GB 7200RPM SATA/150 16MB Cache
1 x Connect3d ATI Radeon X1900 512Mb Crossfire master card edition
1 x Connect3d ATI Radeon X1900XTX 512Mb DVI + DVI + VIVO PCI-E
1 x MSI RD480 Neo2-FI SKT939 2xPCI-E Crossfire support DDR400 8channel audio LAN ATX
1 x AMD Athlon 64 XP3000 (my 4800 didnt turn up today)
2 X 1GB Paired PC3200 Ram (in duel channel config)
580w PSU
I have set it up in crossfire mode (just enabled via the ATi software?) and everything seems to be running fine apart from games. Did have the cpu overclocked to 1900 but put that back to normal and it still falls over. Im thinking that maybe its just not enough power.
The PSU says it has X2 12 volt rails one at 20amp one at 18amp but the manual doesnt decribe if one of the sockets is the 2nd 12v rail or not (its a moduler deal where you plug your cables into the psu).
(just found link to it: http://www.overclockers.co.uk/acatalog/Hiper.html )
Is it what i think it is or is it something else? How much power do you think i need for this system (im now thinking a 700w the Sparkle FX700-GLN maybe)?
I Both video cards have their own cable with nothing coming off it to leech power that way. Im going to try unplugging the DVD and 1 of the harddrives to see if that helps.
If all else fails would it be safe to use a second psu just to power the video cards? (have it outside of the case conected to both of them?) just until i get another psu?
Edit: just read in another post that someone had problems running a crossfire setup with a 600w supply and it worked with a 700w supply so i think this is the same problem. Wouldnt mind some confirmation though and a suggestion for a good PSU.
Edit 2: just tried putting the cards back to single cards and removed the slave card and it run amazingly, for about 20 seconds, then fell over again.
The system is.
580w PSU
). Did a lot of reading before getting mine as I was thinking about Crossfire sometime later. A few people (I think Jokester on here is one) have been having problems running Crossfire with even OCZ Powerstream 600W. Once they've changed to the Epsilon their problems are sorted out. It's not the amount of watts it's the 12V ampage. The higher the better. Off the top of my head Crossfire is recommeded to need around 38A.
