- 28 Sep 2017
Hey guys,
Umberto from BitFenix has given us not one, but SIX samples to give-away to our forum members to review! All you have to do is drop a reply letting us know why we should pick you to review one, and what build you plan to run in it!
Umberto will check through the replies in a week or so and pick his favourite. The only thing he would need in return from you to review a case is:
- A small review in the forum
- A review on the weblisting (links below)
- (Optional) a photo or video of your finished build/review of the case that we can feature on social!
If you've not checked out the ENSO MESH already it's a fantastic case! Based on the original ENSO that launched last a year, it features a fully redesigned MESH front panel, increased fan capacity and now supports up to a 360mm rad.
Other features include:
- Built in ASUS Aura sync compatible addressable RGB lighting.
- Two pre-installed 120mm fans (one RGB rear fan, one black front fan)
- Options for up to 6 x 120mm fans, 1 x 360mm front rad and 1 x 120mm rear rad.
- Storage capacity for 2 x 3.5" drives in the caddy located beneath the PSU shroud with and additional 3 x 2.5" mounts located behind the motherboard tray.
- Front I/O with 2 x USB 3.0, 1 x HD Audio and RGB colour cycle.
- Quick release magnetic lock front panel, top mesh cover and PSU filter that slides out the side of the case. (so no excuses for not cleaning it!)
If you're interested, just pop us a message below and good luck!
Bitfenix Enso Mesh Midi Tower RGB Gaming Case - Black Tempered Glass @ £84.95 inc VAT
Premium quality Midi-Tower case, Mesh front-panel, Tempered glass side panel, Addressable RGB on front panel, Up to E-ATX Motherboards
Only £84.95 inc VAT.
ORDER NOW
Bitfenix Enso Mesh Midi Tower RGB Gaming Case - White Tempered Glass @ £84.95 inc VAT
ORDER NOW
and to compare the temperatures to see just how much a difference a closed front and mesh front make.
