Enthoo Luxe
30 Oct 2010
Scotland
Can any Enthoo Luxe owners tell me the space behind the motherboard tray and the door ?
And any views on the case in general, bad / good.
I can give you an exact measurements this afternoon but it is quite spacious. I have a ton of cable extensions all braided alongside various temp probes and fan cables running behind.
It's mainly to see if there is space for tubing, it seems to have a deeper sction at the bottom with space for a double ssd bracket, but is less space above that.
25mm might just do the trick.
It does have a deeper recess along the bottom. And I have tucked my drainage tube there so you should be good.
The plan is 2 tubes behind the motherboard tray, need to run from top to bottom roughly where the grommets are, so that would be the narrower space, which seems to be 25mm according to the other post.
You can fit atleast two Samsung evo ssds on top of each other if that helps
It's not the space for SSD's it to run watercooling tube behind the motherboard area, so it's the depth between the motherboard tray and side panel.
The narrow part at the top area not the deeper part at the base.
