- 12 May 2010
- West Bromwich
Lads,
Posted a couple of q's in WC about this case which I was looking at purchasing for my Easter rig maintenance. This question goes out to anyone with w/c rads in the case.
I want to put an RX360 in the roof, which I am 100% certain will fit in a push config and wont be an issue.
However, if I put an EX240 in the base, will I loose the HD cages, or can you have all the HD cages in there as well as a 240mm rad.
Also, as I've never put a rad in the bottom of a rig before, do you have the fans sucking air up from underneath, or blowing down through the base.
Cheers.
Cheers.
