Just trying to understand this properly.
What everybody seems to be saying is that all fans plugged into the hub will cannot be individually controlled. They will all run at the same speed?
What I wanted to do was plug my CPU fan into the motherboard then the hub into the CPU OPT port and then the case fans into the hub to control them both separately.
They don't seem to show the RPM in the software I'm using.
EDIT: Im using a Asus Ranger VII board and the Asus Suite 3 software.
So can't have case fans and CPU fan seperate?
