SiriusB said:Unless you have some highly sensitive data on your PC a single format should do. The guy you sell it to in the Loot is unlikely to have the thousands of pounds worth of hardware and software to extract the data![]()
smids said:Yeah, e.g. WD have a write zero's to the drive function which doesn exactly as it says, making the drive RAW as if new. No data can be recovered after this I believe.
Good pointps3ud0 said:Just make sure whatever you use doesnt touch the partition table...
ps3ud0![]()
Me sees dead fanboys theresmids said:/OT - what are you doing in [the HDU] forum, shouldn't you be playing with the 'big boys' in the graphics forum?![]()
