Error 777 - Connecting two computrers
11 Nov 2004
Macclesfield, Cheshire, U
Hey. i just got a new computer like a hour ago :D
i want to let my old one connect to the internet through me
(Im using a 3G Wireless Modem).
and also i want to get all my files of the old CPU.
I get Error 777 on the old CPU when trying to connect.anyone got any help for me?
When trying to connect with what?
The first step should be getting it to connect with just the new machine; adding the second should be simple after that.
Edit: Why the bold tags? :confused:
So you have two machines and two cables and you've connected the two machines to the DG834G, and one/neither can access the internet?
If that's how you're setting it up, one machine isn't "going through" the other at all and it should just work. Where's this "error 777" coming from?
No , i auctually just did a str8 connection From Port too port.
i was just saying what i had to play with for suggestions.
getting Error 777 from Client trying to connect to the host after dile.
Ok, i cant find one of my small wires now. but i have found a wire with two large phone connector ends. and ive connected them from PC to PC. My Network connections say that Local Area network is connected. and the sent packets on both computers are ticking up. But not recived. Is this working?!? , i tried to goto \\COMPNAME, But it diddent work.
When i click Repear connection, Client Gets -"Error Clearing DNS cache"
And Host gets "Error Clearing ARP cache" ( cmd promp tells me its empty anyway!)
Port, on?
If you've got a router (which has a built-in 4 port switch), two machines, and two ethernet cables (if they are ethernet cables), it would be stupid to try and connect one machine through the other if you don't have to...
After what? If you're using a DG834G you shouldn't need to dial at all...
Well i dunno because i have a USB modem, and my Router dosent have a USB,, and i cant find one of the cables,, now i have Two with Two large ands and one with Two small ends. The router only lets small ends go in the main slot.
You'd need to disable DHCP on the DG834G then, and set up ICS on whichever machine you connect the 3G modem to. Does the 3G modem connect on the new machine (assuming that's where you want to use it)?
Ive just bought a crossover cabel. and connected direct with that.
When i click Repair on the connection i get a error saying Unable to clear ARP cache.
i go into cmd prompt and do arp -d to clear cache, and it says its empty.
i still get the same error. << This is on the main computer
the other computer gets clearing DNS cache problem.
Heres some cmd prompt screenies, may help people help me.
this is driving me crazy lol. When i try to ping either computer it sends 32 Bites , then it fails.
How about starting with the basics..
Connecting the two PC's together
1. Unplug the 3G modem (Just to stop that having any effect)
2. If you going to use a cross over cable.. make sure you manually set the IP Addresses on each PC.
If you set one to 192.168.0.1, then set the other to 192.168.0.2
3. Now try to explore the other PC using \\ip-address and see how it goes?
Both Machines = Windows can not find this adress.
The odd thing is if i ping the main computers name (DODGE) from the seccond computer it finds its IP , then fails the ping. Where as if i try to ping the seccond computer from main (YUMMY) it wont find it...
