Error Code 0 - Compression?
18 Feb 2006
Anyone know of a way to compress a video file to less than 4GB? Tried the built in compression, but didn't get it below 4GB :(
I can't format my external, as it's not just for the Mac, so that is out :(
The file is a .mkv and is 4.37GB.
I could just compress it in say MPEGStreamclip, but as it's 720p video content, i don't want to lose the video quality.
Any ideas?
Instead of compressing the file is it not possible to split the file in two?
Could do, but wouldn't that mean re-compressing the video?
Is there .7z or similar, for archive compression that i could then just expand when on the HDD?
To simply split it in to chunks for storage:
Terminal: split -b 4000m mybigfile.mkv
To rejoin the the chunks on a drive that will support the big size:
Terminal: cat chunk1 chunk2 > mybigfilerejoined.mkv
Edit - That's just slicing and dicing the file, so you don't have to worry about compression or degradation of video quality.
