Errors on Memtest86. need help
6 Mar 2010
Hey all
I brought the cpu, mobo, as a Bundle. which are
CPU:Intel Core i7-4790K
Motherboard: Gigabyte Z97X-Gaming 7 Intel Z97.
And the ram i brought was Avexir Core Red Series 8GB
When i install the avexir ram they was getting errors on memtest86
I went out and brought some Corsair Memory Vengeance 32GB, 16GB for me and 16GB for my brother, i have install them in and all working but i have had some random BSOD :(.
i have just run memtest86 and i am getting lots of errors on my new set of ram on test 8.
I need some help could i be unlucky and got some more ram that are faulty or could the problem be my mobo
thanks danny
I'm in a rush to get out but...
First screen - shows only part of the 8GB memory and also triple channel, which is wrong. Also it looks like you have not setup the correct memory timings as the ones shown are also wrong. This would need to be done, not sure about the voltage as that does not show.
Not sure about the correct memory settings for the Corsair memory, they appear to be reasonable but you need to make sure that they are correct. Same applies for voltages.
It does not show dual channel but seems to load a XMP profile so that might be ok.
Ensure that you are using the correct slots for dual channel support.
On the old memtest86 it do not show the infor right but all setting right i tested the avexir with memtest86 v6
<<<<<lol
i have check my bios setting for the CORSAIR ones
test one ram stick at a time in memtest,you could have a faulty stick
i going to test each stick in each slots and i well post back thanks all
The avexir timings do not seem right compared to their advert, also check the voltages.
Indeed the Corsair seem fine, with timings etc but as noted check each stick individually.
Good luck
Good luck
the avexir ram been sent back
the Corsair ones i tested each stick in each slots and one off them get errors in each ong and get 1 error in my borther pc the other stick only get errors doing hammer test when using memtest86 v6
