- 12 Jan 2006
What exactly do they mean?
My cpu is running at 30oC atm, but the voltage is at 1.37 even tho i have set it to 1.40 (but i assumed less voltage was needed so the system reduced it).
Ok to the problem;
i ran the in place large TFT Torture Test and it would give the error:
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt.
Torture Test ran 0 minuites - 1 errors, 0 warnings
According to the stress.txt this is a hardware error, so does this mean i have reached the limit my cpu will go or i have just chosen some funny settings?
Opteron 165
FSB: 289
Multiplier: Auto
Voltage: 1.40v
Thanks in advance
Clocked back down to 2.3 the results are 100% pass
Ok to the problem;
Opteron 165
FSB: 289
Multiplier: Auto
Voltage: 1.40v
Thanks in advance
RAM: CPU/11
