errr ok............3038...
9 Jan 2003
Cornwall
Project : 3038
Core : Gromacs
Frames : 100
Credit : 186
-- Folding 1 --
Min. Time / Frame : 36mn 18s - 73.79 ppd
Avg. Time / Frame : 36mn 18s - 73.79 ppd
-- Bot 001 --
Min. Time / Frame : 28mn 52s - 92.79 ppd
Avg. Time / Frame : 28mn 52s - 92.79 ppd
Bot 001 is a barton 2500 with 512Mb ram.
Folding 1 is a core 2 duo E6300 @ 3.2GHz or so with 1gig ram.
ideas?
Is SSE working on the C2D?
Project : 3038
Core : Gromacs
Frames : 100
Credit : 186
-- Capricorn --
Min. Time / Frame : 25mn 11s - 106.36 ppd
Avg. Time / Frame : 25mn 11s - 106.36 ppd
That's an XP1700 overclocked to 2050 IIRC so if your Barton is running at stock that's probably about right - just that weird C2D result then :confused:
Project : 3038
Core : Gromacs
Frames : 100
Credit : 186
-- //Krusty/F@H2/ --
Min. Time / Frame : 11mn 48s - 226.98 ppd
Avg. Time / Frame : 12mn 02s - 222.58 ppd
-- //Krusty/F@H1/ --
Min. Time / Frame : 12mn 12s - 219.54 ppd
Avg. Time / Frame : 12mn 12s - 219.54 ppd
That's what your E6300 should be doing. That's what mine was doing before I switched it over to SMP. Overclocked pretty much the same as yours.
As Rich suggested, try checking SSE. Also, check in task manager to see if anything else is using up the CPU cycles.
Stan :)
Sorry to go off topic here but I just realised that my XP1700 has the same overclock as Rich's (2050) and it's PPD for these is almost identical to his.
Stan :)
[21:52:43] Preparing to commence simulation
[21:52:43] - Ensuring status. Please wait.
[21:53:01] - Looking at optimizations...
[21:53:01] - Working with standard loops on this execution.
[21:53:01] - Previous termination of core was improper.
[21:53:01] - Files status OK
stop the client and restart it - that should get SSE working again
to aviod it in the future get the -forceasm flag into the image path for the service using regedit
or computer management rather than titing around with regedit.
you can try it in there - maybe I've done it wrong before but the changes didn't seem to stick when I tried before
If there's a particular trick to it can you let me know?
just add it to the box it has for extra commands, have to be logged in as an admin to do it iirc, and I'm unsure if it has to be done for each used (group policys ***)
