- 10 Oct 2008
I have a new 1TB Seagate FreeAgent Pro (the one with eSATA).
It works well on USB but not in eSATA.
After following many hints and tips on the web (eSATA seems to be very problematic) I now have it recognised in XP, but it’s still not working well…
Even though the drive is recognised by XP… the drive seems to stop and re-start whenever I try to read or write large (> 1mb) files.
The orange light also dies away when this happens.
The only way out is a re-boot of XP.
This then results in the blue-screen CHKDSK running….
So I assume the problem is corrupting the drive data.
Things I have tried so far.
1. Update motherboard BIOS to latest (P5B Deluxe)
2. Checked eSATA cable is correct one, plugs into the socket with no interference from the plastic shroud.
3. Updated the JMicron driver on Motherboard.
4. Set the FreeAgent sleep timer on never.
What else could be causing the problem?
Any and all ideas are really appreciated because I’m pulling my hair out !!!!
Many Thanks in advance.
PS, I have three other SATA internal drives that work well.
Ray
Ray
. this time i turned it on with the drive attached and it works fine. turned the drive off and on with the pc turned on with no ill effects.
