couldnt find a quiet psu for the netstor. decided to change tack for my build
All prices inc Vat
SFF8087 to 4 Sata QTY 2 = £24.96
RocketRaid RR2720SGL 8 Port SAS/SATA III RAID Controller QTY 1 = £125.98
Be Quiet Dark Power Pro 750W PC Power P9 BN174 QTY 1 = £137.57
Fractal Design Define XL Full Tower Case QTY 1 = £104.99
Total = £393.50.
Controller only has 8 ports (but controllers start getting a lot more expensive after 8 ports)
Case doesnt support hotswap, led indicators (not really required as long as i label up)
i am pretty sure Case will be silent.
Phase 1 - run htpc and storage case at same time, feed 1m sas/sata cables to storage case from controller.
Phase 2 - use the new storage case/psu for a new build i was planning anyways. save £250
all i need now is a good value/quiet 5.25 bay to 3.5 hdd converter to support a bit more HDDs storage in the fractal design, when required, given a future motherboard will support a 4-6 disk raid 5 array as well and the fractal design only has 10 bays.
any thoughts please, will these parts work together?
Any other good quality cases with 10+ hdd bays?
If you are really determined to get a Highpoint controller then why not the 2722 which has two external ports (SFF-8088). You could get some temp SFF-8088 -> SATA cables to run into the hard drive case and direct to the drives and then replace them with SFF-8088 -> SFF-8088 cables, a target SFF-8088 -> 0807 case bracket and a SFF-0807 -> 4x sata when the need arises. The difference in price between the 2720 and 2722 is only around US$60 in the US.
Second question would be why the 750W PSU. If you factor each drive as requiring 10-15W then you are significantly overrated (the PSU that is ). For 8 drives you could get away with a 150W Pico PSU with the brick in the case if needed. No noise at all but may need some quiet fans for HDD cooling.
3 -> 5 drives hotswap enclosures are around US$100 so maybe 80 quid. That would give you 15 (3x 3->5) with one bay left over. You would then need a SAS expander to handle all the drives and use a wide link (2x SFF-8088 -> controller). The only other realistic option for a single case to hold all those drives is a rack mount 4U case which can go upto 24 drives like the Norco 4224. I have a 4020 and it is great but in hindsight would now go for the 4220 as it uses one SFF-8087 connector per backplane rather than 4xSATA.
RB
