Hi All
I am getting a loft conversion and have decided to use this opportunity to wire up both CCTV cameras which use powered Ethernet which will go to a recorder box or possibly cloud recording and some wired Ethernet ports. I think these will need to all go through a switch or a network panel of some kind.
CAT 5e is fine for my needs so I will use this.
Can anyone recommend a switch that would be suitable for both purposes ?
Thanks
J
Thanks
J
