Ethernet cables
Cat 5e unshielded is fine for the home. There is just no need to buy expensive cables. I don't think OKUK sell cables so I am safe in saying the Kenable are a good supplier. They offer quick delivery and their cables are not overpriced. You may actually find some difficulty in getting Cat5e these days, Cat6 is a fine replacement.
cat10 can be had for cheaper than cat5e, no brainer :D..... or no brain if you buy it :confused::confused::confused:
Hi all
I'm just looking for more info about Ethernet cables, I see there are so many and I've not got a clue what's what :p
Cat 3
Cat 5
Cat 5e
Cat 6
Cat 6a
Cat 7
Any information would be great to help me understand
Thanks
If you can get a cat7 cable for the same prices as others just do it, better shielding etc usually - I put cat 7 all around the house a while ago was no dearer than cat6 cable on amazon actually cheap and easy.
I beg to differ. Firstly, REAL CAT7 is a beeatch to terminate, especially if you’re doing a lot of them. It’s a massive, heavy cable reel to cart about. All the extra shielding makes it MUCH harder to bend than CAT6, then once you’ve got it run in, you have to VERY carefully remove the outer sheath so you don’t take off the primary shielding, then you have to strip off 4 extra sets of sheathing, untwist the pairs, get them into the connector, and THEN you still have to terminate the primary shielding to the connector, making sure none of it is exposed so it could become a conductor to nearby cables. Good luck!
Plus, the actual plugs and keystones are crazy expensive because of the amount of metal in them.
Unless you’re inclined to brag about how much your network install cost or you got everything for free off a building site your brother works at, I can’t see any reason to have CAT7 over CAT6 or CAT6a.
Yeah, CAT6 is fine, just make sure you get one with high MHz. Blackbox make some good 550mhz stuff which will happily take a full 10gbe connection
If you do the maths, to do 10GbE over the 33m/100’ rated distance you don’t even need 250MHz, which is what CAT6 is rated.
By all means buy ‘special’ 550MHz cable but don’t be shocked when it doesn’t do anything extra over CAT6 250MHz.
Yeah sure thing, but the point is it's still CAT6 and at a normal price. No need for CAT7 or whatever.
It’s like gold plated phono cables. Or that special hi-fi speaker cable that only dogs can hear the difference. It’s marketing. Gotta love marketing. “we made this special 550MHz CAT6 cable that doesn’t pass CAT6A certification but it’s better than 250MHz CAT6”. Or maybe you bought up a load of rejected CAT6A cable and tested the frequency throughput and made up a new marketing term. 550MHz CAT6. How is it any different to CAT8 or CAT10. It’s not a real standard. It’s a marketing term.
The point is in the price. I wasn't pony'ing up anything extra over any other CAT6 cable. Ok, a few £ extra for LSZH casing, but only about £5 on top per 300m. The gold plated nonsense and daft speaker cables all have one thing in common - a price hike.
All in t saying is the same as you - don't get suckered into paying for unnecessary
The only place I can find this 550MHz cable is Blackbox. They sell it under a different menu tree on their website from CAT6 called ‘Performance CAT6’ and I hate to break it to you, it’s quite a bit more expensive than their 250MHz CAT6. It’s marketing BS. They might as well call it CAT6 Unicorn grade, it would be as useful.
You’re saying “don’t get suckered into paying for unnecessary” and yet for the use case in the OP CAT5e would do. CAT6 would be a luxury. But you don’t recommend standard CAT6, you name Blackbox 550MHz CAT6 as the one “guaranteed to get you 10GbE”. Those two statements don’t stack up.
No. Non CCA 5e will do 10Gb over very similar lengths to 6, those lengths are likely to be the sort you’ll find in your average domestic install (without a separate guest/servants wing). Suggesting anyone needs to make sure it’s 550Mhz cat6 for 10Gb is - at best - foolish.
Hello, I'm very sorry to post a variation of a question that's already been asked a million times, I'm just a complete novice with all telecomms stuff. I did read the sticky which was very helpful, but was hoping someone could just confirm that I've got things correct.
I'm moving into a house with no phone line, Sky are arranging for Openreach to come and install it/the master socket. Ideally, it will go in the (converted) loft space. Would I be correct in thinking that I can use a Cat 6 cable to connect the master socket to my router downstairs? (dropping it through the ceiling). This is the option that would be easiest given the current cabling already in place in the house, I just want to make sure it would actually work? We don't have any special requirements in terms of Wifi/devices etc.
Also, if this is correct, should I purchase a Cat 6 cable with a plug thing on the end, or just the cable as it is?
Many thanks for your time!
