Ethernet cabling
18 Feb 2007
London
hi
Thinking about getting an Asus RT-N66U router so then I can put my vm superhub into modem mode.
I would then be able to move the Asus to a better location but I would need to run 3 ethernet cables to it as I have a few devices near my tv that need wired connection .
All I need to know is, is it ok to run ethernet cables together or would it create interference/heat?
thanks
Could you reduce the cables down to one by using a network switch at the TV end?
Don't forgot there's often an option of going straight through external walls and running cables externally.
I guess , would a network switch have any decrease in performance issues?
although I think I would still need to run 2 cables anyway, 1 for the superhub and the other for the network switch?
A single Gigabit link between your router and the TV should be plenty. Most TVs and associated devices only have 10/100 ports on them anyway.
You may need two cables, it'll depend on where the Superhub is located.
yeah 2 cables so really a network switch would not be worth it
Its because I have a slingbox and a ethernet wall socket located behind the tv which runs a wired connection to the back of the house where I have a wired connected pc
Just have to think of best way to conseal 3 cables I think.
thanks for the help
