- 6 Jun 2011
I am having a really irritating time with my ethernet connection since moving home and I was hoping someone may be able to offer some advice on what may be the cause and also any possible solutions.
It is BT broadband and it is a Homehub 5. At the previous house the setup was Homehub downstairs and a long ethernet cable upstairs into the PC with no issues whatsoever.
Since moving I have got the Homehub downstairs and have been forced to useTP-Link Netgear 1000 Powerlines as opposed to the long ethernet cable unfortunately. It is the same Homehub and the same PC. Just a different phoneline and the addition of these Powerlines.
Since moving I have found that I am randomly losing connection. The errors can happen at any time, suddenly web pages or videos just start loading indefinitely and then I get a DNS error. The connection icon usually stays the same. If I go to the network adapter, right click>disable, then right click>enable. The connection usually returns immediately until the next time which might be the next day or as soon as 5 minutes later.
I have tried switching out the cables to no avail. I have also tried connecting the Homehub into the test socket and still found the same thing would occur. I have also tried switching off the power saver setting off on the adapter.
I'm thinking it is the powerlines that are the problem but if they are I find it odd that I could disable and re-enable the network adapter to get it going again.
I guess I would be surprised if it was the phone line for the same reason. That said I have had some issues with my phones wifi connection but that doesn't seem to occur as often.
Given BT's reluctance to send out engineers to check the line I'd like to try and rule everything else out beforehand if possible. Anybody have any ideas what it could be based on the above?
