It could quite easily be a university network that only lets you plug in one device.
fine someone who doesn't use theirs and patch a cable to your room
right i am at university in the halls and they let us have one Ethernet conection in our rooms and there is wireless on a different network that all the internet i can pick up now the internet over wired run past a check or something the uni do that looks at the mac address my xbox laptop and pc are all registerd and alowed to be used but the rules of the uni say i can not split the signal using a router or something
so as i would need to register the mac address of anything i plug in or if the uni find something pluged in with a mac address that's not resisted when they scan there network i get my internet switched off until i remove it.
so i am looking for a way to plug my xbox in to the network along with my pc so i can have internet on both and can stop switching cables about.
if i switch will not show up on there scans then i will get one but i dont know if it will
And you got into University?right i am at university in the halls and they let us have one Ethernet conection in our rooms and there is wireless on a different network that all the internet i can pick up now the internet over wired run past a check or something the uni do that looks at the mac address my xbox laptop and pc are all registerd and alowed to be used but the rules of the uni say i can not split the signal using a router or something
