Ethernet port/wire going?
Some more info about your issue would be useful. But if you think its a cable problem, cant you just test with another cable? Maybe you will have to move your computer temporarily if you only have short cables spare, but worth it to test.
It was the wire one of the smaller wires didn't connect with the head... Strange though all accept for night before last the same wire worked fine...
