 - 27 Jan 2012
 - The king of the north!
Hi everyone hope you are all well,
Networking really isn't my strong suit so always like to check in and get advise here rather than winging it.
The room i spend most time in has pretty poor wifi signal so i have a Cat5 cable running into here that i plug into my laptop. I have been running connectify on the laptop to use it as a hotspot for my mobile phone. Whilst this works well, it would be much nicer to have a decent wifi signal in here instead. I think what im looking for is something that i can plug the existing Ethernet cable into that can then provide a wireless signal to my phone + laptop. If it's not possible to share this single line between the two then that's okay, i would just connect the laptop to it and continue to run connectify.
I will still be playing a few games where a stable network connection is required so that's something id like to keep in mind with this.
Would this be a good solution? what would you guys suggest hardware wise ?
Cheers
Harry
Cheers
Harry
