Wireless is fine according the eufy install process and a WiFi survey app on phone. I get loads of alerts, mostly with nothing to be seen on the recording.
Daft suggestion, do you have another phone to try the app on.
Are you sure you dont just have the "detection type" set to "human only"? Mine doesnt detect cars pulling onto the driveway either but I wouldnt expect it to as I deliberately have it on the human only mode.
Wedge is 35mm wide and 120mm long.I was going to ask if anyone can provide the exact dimenson of the 15 degree wedge that comes with it, I am in a new build property that has a wired doorbell mounted on a fairly narrow frame. I am hoping the wedge might allow me to mount this in the same place as the exisiting doorbell so i can also use the existing wires
Wedge is 35mm wide and 120mm long.![]()
Pretty sure you can just draw the area you want? Or you can on others?How short a distance can you set 'human only' mode to?
My front door is about 2m-3m from the pavement.
