The battery doesn’t drive the wheelsAll depends on how things are designed, ICE cars now have loads of parts that would have to be removed to just to change a sensor, where as a battery could be changed relatively quickly if designed for it.
You said energy storage in your quote. Also an electric motor is far less complex than a ICE engine.The battery doesn’t drive the wheels
That's why I said designed for swapping out. One company already does it but you have to go to their outlet to have it changed.But they don't make them easily swappable, they build the whole car around it and even make it structural in some. So the cost of replacing it is basically disassembling and rebuilding an entire car.
Whereas a whole engines can still be swapped in a couple of day by someone who knows what they are doing. You can also find used engines dirt cheap for most cars.
Basically they had no repair supply chain in place so they basically wrote the car off as an insurance claim. Couldn't repair a nearly new car through a third party due to warranty and insurance.Stealer being a stealer, quoting £35k to replace like-for-like, no idea what the laws in Canada are like (or the insurance) or why the warranty was void? It's easy to make a headline of of a single case for anything, just go and look at the F1 Miami thread, then you'd think all food cost $280 fora sandwich.
A battery is easier to fault find as it either works or doesn't.Where do you get this stuff from? Battery swap is much easier.
Repairing a battery takes longer because you have to take to battery pack apart..
Have you ever seen a nio battery swap station?But they don't make them easily swappable, they build the whole car around it and even make it structural in some. So the cost of replacing it is basically disassembling and rebuilding an entire car.
That's the one I was talking about. It's not a perfect solution but better than most.Have you ever seen a nio battery swap station?
the car even drives itself into the station, 5 minutes later you have a different battery.
Fuel tank swap vs battery swap. That’s all. Most engines last longer than the car now. Not sure about batteries lasting longer than car yet.You said energy storage in your quote. Also an electric motor is far less complex than a ICE engine.
I watched bjorn nyland do it on YouTube.That's the one I was talking about. It's not a perfect solution but better than most.
I thought it took 10mins. Wasn't it on Top Gear?
True, but if needed it shouldn't be a difficult process or too costlyThere were lots of battery swapping systems tried and working years ago.
None took off because it's a completely unnecessary and over engineered solution to problem that doesn't exist for the vast majority of people.
The vast majority of people don't need F1 style pit stops. If you're someone who does, need rapid pitstops on very long journeys buy a diesel.
EV have made huge advances in very short period of time. Battery swapping isn't it.
But then you need more batteries in the system . And as the most expensive part of a car do you really want to be constantly swapping them out not knowing if it’s a good one or not ?True, but if needed it shouldn't be a difficult process or too costly
