per location too, not sure if need to schedule when I’m not at home but it will do it.Supports multiple schedules now.
Guess it depends on the car, Tesla's as smart enough to know to apply the schedule where set and ignore everywhere else.
For those who Granny charge what are your setups like?
Do most of you just put it through an open window?
Or in the case of those charging overnight have you set something up so windows aren't open etc?
I know how I'm going to do it but interested in other peoples ideas before I do it.
Not much difference in expense fitting a proper charger if you're doing that though.edit: if you are going to the trouble of adding a new circuit for an outside socket, you might as well use a commando socket and get the full 32A from it.
The same can be said for if there isn’t a suitable existing circuit you can run an outside socket from.Not much difference in expense fitting a proper charger if you're doing that though.
Not sure I said that but ok. Ultimately people do the commando socket thing because it’s cheaper and doesn’t carry the EV charger installer premium.you aint pulling 32A from a simple socket, if you run 6mm cable why make your house look like a camping site.
My sister and bro-in-law both own an EV and just have an outdoor weather proof mains socket like the photo above. It depends on mileage/usage but I'd have thought most people could charge an EV just using the granny charger 1/2 times a week overnight or at the weekend. It's not recommended to leave an EV battery at 100% for a long time either from a long term battery life pov. So unless you need it just set the cap to 80% charge in the car settings.For those who Granny charge what are your setups like?
Any info on that external socket would be appreciated. I keep reading about many not being big enough for the thermally regulated plugs and charger cables. The fact that one locks would make me happy about leaving the cable attached which is a big plus.
You don’t have to make it look like a campsite and most chargers on the market look trash anyway, particularly tethered chargers that don’t side the cable. For example, the Zappi literally looks like a toilet seat.
Like is said, it’s a grey area, it’s only significantly cheaper if you install it as a general socket. If you did it to all the EV regs, it probably wouldn’t be that different on install costs.
The portable EVSE would be a lot cheaper than a ‘proper one’ as it wouldn’t need to have all the smart stuff in it. The downside is you need a compatible car to access the very best smart tariffs.
If you need to run a new circuit for an outside 3 pin socket (as the guidance suggests for EV charging), you might as well run it in 6mm and put a commando on the end of it. The cost difference would be negligible.
It's this one. Plenty of room to shut and lock a big plug. It's only locked with a plastic fixing - but enough to deter a casual grifter. There's a ring camera directly above it too.Any info on that external socket would be appreciated. I keep reading about many not being big enough for the thermally regulated plugs and charger cables. The fact that one locks would make me happy about leaving the cable attached which is a big plus.
I think you missed a key word in my post, I’ve bolded it for you below.Well you did, you suggested the wiring was appropriate inside the house for a 32A commando plug, There no 'ok' to magic electrons down a cable to thin.
If the ring main/wiring loop isnt good enough for 32A then you need to run a 6mm cable from the consumer unit, once youve gone to that troubl thats a a BIG jump in effort. You can spur a 3 pin off pretty much any wire in the house for 10A!
Pretty straightforard when you actually visualise the system being recommended and the work to fit it!
