- 4 Aug 2007
- Wilds of suffolk
Not sure I agree with that and no one is talking about checking Twitter on the cars infotainment screen, that is obviously unacceptable.
Driving without due care and attention is a principle and not prescriptive which leads to a huge amount of nuance depending on the specific scenario that it’s being applied to. There is no blanket if you do X then it’s breaking that law.
E.G. spending a few seconds to adjust the ventilation while sat at a red traffic light isn’t likely to cause you to fall foul of it. If you then pulled away without checking your mirrors and blinds spots causing you to run down a cyclist then it probably would. Looking at the screen or physical buttons was almost irrelevant as it didn’t cause the problem, failing to check the mirrors did.
Maybe, who knows, its difficult to know what hes going to be staring at and playing with for a few seconds, could be watching the vent controls I guess
BUt really it doesnt matter, anything thats not considered essential from driving falls under the catch all of dangerous, if by definition, doing so was dangerous.
Eating food, drinking water etc all count.
Clearly when moving most things bring completely different points when you would reasonably be considered dangerous.
The thing is the law and motoring is very black and white, with most references being in charge of as opposed to driving. Eg being inside a car with the keys whilst drunk is still an offence whether you intended to drive or not.
Its going to take some wierd cop to go for that offence but still...
Hopefully at some point the law will catchup. There should be a reasonable defence of automation where the driver effectively hands over control and ceases to be incharge. But as I said this is going to go into an as yet untested area, who will become responsible, the car maker, the software designer, the sensor manufacturer, all, its going to be interesting.
