- 14 Oct 2007
- newcastle
Loads of good points on there that I wasn’t aware of, thank you.Has the additional losses and time from rapid charging a cold battery been factored in?
If you plug in the car it will kick on the heat pump and rear motor (and front motor if fitted) to rapidly heat the battery.
Once it’s up to temperature, it will flip to max cooling.
Being realistic the battery is always going to be cold as you’ll not be coming off hours of driving before plugging in.
You are never going to hit the advertised charge time as it assumes a fully preconditioned battery. In winter it’s going to take a material amount of additional energy and more time to charge the car.
As for getting an EV to save (at best) £500 a year but only relying on public charging, that’s a no from me.
I’ve even got a bank of rapid chargers 5 mins walk from my house, I still wouldn’t even if they were 45p/kWh and not the 69p/kWh they actually are.
You are basically jumping from one volatile market to another. Particularly once you factor in charging you may have to do elsewhere which could wipe out a lot of that saving anyway. Likewise if you want/need a 100% charge, you are sat there for at least an hour.
