you're on a fixed contract and this price was after the 3.5p reduction in Feb though. no supplier is offering off-peak rates that low nowadays.4.5p
If you are getting solar and a battery, even a small one, you should prioritise the lowest import rate possible for 5 hours or more and export. This is particularly the case if you have an EV.I'm home all day (retired early) So need some cheap energy during day (including Gas). Getting Roof Solar plus a small Battery soon as well.
Next Fixed 15m v7
Fixed term ends 10/06/2027
Elec: 19.93 p/kWh - Standing Charge: 45.70 p/day
GAS: 4.96 p/kWh - Standing Charge:34.55 p/day
I did the same too : my off peak rate is 3.99p until 11th AprilYeah I fixed not long before the orange man started his shenanigans. 6 months left of this price before the good times end.
Hi just curious what size battery did you go for with your solar?I did the same too : my off peak rate is 3.99p until 11th April
With my solar & battery storage I will only touch the standard rate a few times in Winter.
It's 10 kWh.Hi just curious what size battery did you go for with your solar?
OK thanks. I've gone for a 5.76kWh Battery, I could only get 7 panels on my roof so have 3360kW.It's 10 kWh.
In Winter we use about 15 to 18 kWh per day, so only on full cloudy days do we need to use the Grid at full cost. When I got it in 2022, a 5 kWh battery was £2.5k, so it didn't make sense to go for anymore for the little use it would get.
I think you can get solar panels installed now instead of roof tiles if you need to replace roof.On the point of solar, is there anything other than orientation (E/W for main house roof, with some S facing on side roof) i should think about? Just moved house and need to get the roof replaced as it's still the original 1930's roof without membranes etc for the majority of it (house was reduced by vendor after the survey pointed this out). Stronger battons?
Check out the solar thread in home & garden section.On the point of solar, is there anything other than orientation (E/W for main house roof, with some S facing on side roof) i should think about? Just moved house and need to get the roof replaced as it's still the original 1930's roof without membranes etc for the majority of it (house was reduced by vendor after the survey pointed this out). Stronger battons?
Solar Panel Roof - Spirit Energy
Learn how to achieve the complete solar panel roof using specialist modules and mounts for a flawless finish and maximum solar power generation.www.spiritenergy.co.uk
You should save costs if replacing the roof by foregoing the tiles and just have integrated panels on every aspect possible.
electrek.co
& Khan doesn't seem to be celebrating tesla taxis on the roads either.
what are the top 2 selling evs this year in the uk?Are they redirecting monies into next evolution of car platform - it has become a two trick pony Y/3 whilst the chinese do their rapid churn thing;
