EV general discussion
Well, the 24h test drive has paid dividends for Polestar, but not so much my wallet. After going to Tesco, and then the school run, the wife has said she likes it and wants one. Secretly, I want one too.
Well I may be discounting the Smart #5 as the dealer quoted £4000 to have the OEM electrically deployable tow bar retrofitted which is insane.
Sure I could have a 3rd party detachable fitted but with modern ADAS systems, that can be problematic in its own right. I also don’t want to have the mechanism visible when not in use. That may be possible but it means a bottom loading swan neck which is a pain in the bum to actually use.
The OEM Polestar bar is £1800 mind so it’s not exactly cheap either but it’s literally half the cost and very easy to use.
The OEM detachable bar on my Y was £1500 but that’s a bit of a dogs dinner also and results in skinned knuckles every time you use it.
Yeah towbars cost a fortune afterwards compared to when speccing up new unfortunately :(
That's frustrating. BMW won't retrofit one, you have to do it yourself and get it coded, then there's warranty implications and apparently some models have extra wiring/cooling when selected at factory. That is one of the reasons I've been struggling to find a nice used G05 X5. Same story with Range Rovers, apparently dealers don't like or want to retrofit, and again you end up in the same warranty headache.
I learned that Volvo will fit one to any supported Polestar, for a price of course, as all the wiring/systems are in place on all cars.
I just wish the Polestar 4 SUV had more colour options.
