Yeah not sure you need 8M but they aren't cheap!Yeah a work colleague has gone Anderson as it wl be right next to his front door and i was tempted too, just with the 8m cable aswell it was looking like double the price![]()
Yeah easy £1k then £80 for longer cable and another couple of hundred for the wooden face panel. Looks great though!
Electric car batteries have been developed that are capable of charging in 10 minutes and would allow a driver to travel for 250 miles.
The new lithium ion phosphate batteries, built by US scientists, can quickly heat up and cool down - which is the key to rapid charging and long life.
Isn't the issue not how fast it can charge, but how long it will last being charged at that rate? (ie how many years before it's knackered)
To recharge, batteries need to heat up to around 60C (140F) and then cool down when they are not being used.
Despite their small size, the batteries produce a large amount of power in a matter of seconds and have a lifespan of 2 million miles, the researchers said.
Professor Wang said: "An electric vehicle with this battery could go from zero to 60mph in three seconds and would drive like a Porsche.
Some chargers can be daisy chained but they tend to be more expensive. They’ll load balance and two cars will charge at half speed if plugged in.
Do you have a spare slot on your consumer unit? If so just run a second wire and a new charger. Two cars will charge at full speed.
Yeah I wondered about that, but the only problem is that the cable going from the unit to the charger has to run along the front of the house, and through a small gap behind the front door step. There's no room for a second cable.
Can you get a standard commando socket fitted, and then use the commando version of the Ohme to simplify things?
