Ah sorry. VW are the only batteries that need warming up ?
5kW is significant and a high amount of that will be the cabin comfort aswell as battery management - VW may have a more demanding cabin comfort or infact warm up profile to maximise regen and motor power as soon as possible. If range is going to be a concern then precondition of course serves well to maximise that.
My car for example has heated screens auto turn off below 5C. Didn’t even care in an ICE but as I can configure the Home Screen I can see how much energy they are using through the screen graphics and will turn them off. Less tech savvy will just drive with everything on full whack not aware of energy whilst wearing coats and gloves for that trip to the station.
It’s just science... which I guess why the public will struggle to start with. I think I get the logic of driving to work with the energy demand of 2 kettles on full.
fair concern, can’t be fixed though.
same people probably complain their boiler at home uses more gas in winter...
After reading an article on id3 heatpumps https://www.goingelectric.de/forum/viewtopic.php?f=393&t=58265&start=50
if you are able to pre-warm the car (daytime rates - yes) their benefit may not be so great, unless you live up North.
The heat pump on the ID3 and 4 is a £1.2k option, which is a lot of pre-warming and use before you start to break even.seems a certain amount of irony because the id3 heat pump option, is more efficient/innovative with c02 than anyone else ..
so maybe they did reduce costs on electrical heating implementation.
in the UK market ... It'll be a cheaper option, like for M3 (free?) , tomorrow, with an accelerated delivery, if users really have issues. ..The heat pump on the ID3 and 4 is a £1.2k option, which is a lot of pre-warming and use before you start to break even.
The battery heater is part of the cars build, not something you can deselect as an option, you may be thinking of the heat pump.
The issue is to do with the battery heater using a great deal of energy when it is cold, in order to get the temperature of the pack up to a level VW have deemed acceptable for use, so when doing short journeys of a few miles there is huge amount of energy used just to warm the pack up, and inevitably also the PTC heater to warm you inside the car, so the efficiency looks abysmal. On longer runs the actual efficiency even in the cold is no where near as bad as being made out.
Yep... Thinking of the heat pump!
Do you know if the battery heater is something which can be switched on to Pre warm?
For example the wife leaves at 08. 30, can we Pre heat the car and the batteries?
As we are leasing and only having it for 3 years the car will literally be connected every night so it's always fully charged so if it was Pre heated it should hopefully allow the extra miles.
Yes, you’ll use the same electricity but not from the battery.
Unless you need the extra miles it’s likely to be false economy preconditioning from the grid close to a National increase in demand.
