0-60mph with nothing more than a firm press of the pedal.
Yep. I bought mine while everyone was all doom and gloom that the batteries would only last a few years and they'd all be worthless.
Now, 2 years later I haven't lost a penny on it. If not, it's increased in value.
Always ahead of the curve.![]()
Only once you're in the right gear and revving the engine. You can't just mash the peddle and go. Very different experience.
Sounds useful in a world of increasingly low speed limits and citizens obsessed with recording everyone else's driving.
I've never been ticketed for speeding in my life, but I still like going quickly. Short bursts of excitement, not talking about going 100mph here or driving recklessly. Not that I'm saying things wouldn't be more fun with higher speed limits...Honda E test drive
That's strange - my tyres have lasted really well. I'm not surprised the Goodyear's haven't lasted though. Grip and Performance is almost directly opposite to longevity. I've used the same tyres on every car I've had, and they've worn no different on the Leaf than any of the other cars.I bought my Leaf November 2017 with a reasonable amount of tread on the tyres. April 2018, I replaced the lot as they were near minimum. And I've just bought another new set as again, they're near the minimum. I've done about 22k miles since purchase.
Not no-name budget tyres either. Goodyear Efficient Grip Performance (admittedly not the best out there, but they've been very well priced both times I've purchased).
The Leaf is particularly bad though. It has (unacknowledged) issues with the rear suspension which result in uneven tyre wear. One side of each rear tyre has a few months of wear left in it. I'll get the new ones rotated after 6 months I think.
I've also started to tame my driving a bit. In part, that's due to having a baby. But also due to the tyre wear, and the realisation that the car still has plenty of power in Eco mode. I don't really need to hoon it off the line every time I come to a stop. And the power is still there in Eco mode, as the car has a two stage pedal; push it past the first stop point and you get full power regardless).
Ah, I thought you meant on the leaf. I can imagine the i3 going through tyres quick. Lighter, more torque, and really skinny tyres.It may come down to driver style and circumstance. I have a couple of routes to work and the one that is mostly dual carriageway has one section with 7 consecutive sets of lights so lots of regen braking and accelerating. I was definitely playing a bit to ease the boredom and would rarely let anything lead me away from the lights. As a result the rears were not going to make 10K miles so I've just consciously altered my driving to either match normal traffic or follow cars on left lane.
The i3 only has a choice of two tyre makes being so tall and skinny so I'll switch from Nangkang to Bridgestone to see if that makes any difference.
Honda E test drive
Honda E test drive
Hopefully in the next year or two they bring out an extended version.
