 - 11 Jun 2012
I recently upgraded my desktop and since doing it stability has gone down the drain. New build consists of
And carried some old drives over
Since first boot it has randomly started stuttering intensely and eventually BSOD's with a WHEA_UNCORRECTABLE_ERROR but fails to produce a minidump, BSOD just sat there on x% until I had to forcibly shut down. Seems to be more frequent when playing games. Everytime it does this there's stornvme entries in the event viewer.
Initially I thought the new m.2 which I had installed in the m.2_1 slot was to blame. I tried running every diagnostic I could find and everything came back saying it was healthy but I removed it to be sure. Since removing it seems to last a bit longer without throwing the WHEA_UNCORRECTABLE_ERROR. Additionally since removing it the log shows
For the times where it did BSOD while I was running with both m.2's installed the event log notes an unexpected shutdown and reports about the failed to create the dump:
I've also done RAM diagnostics and CPU stress tests which all seemed fine, and numerous DISM / SFC / chkdsk runs which all come back good.
I'm running out of ideas, I was going to try resetting windows but if that doesn't fix it I'll be back to replacing bits of hardware starting with the CPU followed by the mobo.
Has anyone else got any other suggestions?
			- 5800X3D
 - ROG STRIX B550-F
 - RX 7900 XT
 - 2x16gb Corsair DDR4 Vengeance RGB PRO SL Black
 - SK hynix Plat P41 2TB m.2
 - be quiet! Straight Power 11 Platinum 850 Watt 80+ Platinum
- Samsung SSD 860 EVO 1TB
 - ADATA SX8200PNP
Reset to device, \Device\RaidPort1, was issued. whereas before it was Reset to device, \Device\RaidPort2, was issued.. You can see here there's a whole load of entries, I was playing BG3 when these started and new entries became significantly less frequent shortly after I closed the game around 21:24ish but didn't stop completely:For the times where it did BSOD while I was running with both m.2's installed the event log notes an unexpected shutdown and reports about the failed to create the dump:
 Thanks for posting the images as that rules out a driver/software issue.
