evga 850G2 12V Rail Problem
16 Jan 2013
Stranraer
hi guys my power supply is only showing 11.710v on hwmonitor is this normal for an evga powersupply its only running the specs below so i would say somewhere in the 300-400w range.
17 May 2013
hwmonitor isn't that accurate. The voltage readings in the BIOS are more accurate, but as lee says, the only way to get a true reading is to use a multimeter.
