Evga 980ti problems/maybe problem with system?
6 Sep 2014
Good evening guys and gals,
I've been having a lot of trouble recently with my pc setup the specs are as follows;
I5 4690k @ stock
Evga 980ti with backplate @ stock
Asus z97-Ar mobo
8gb corsair vengeance lp ram
Evga 850w P2 psu
Windows 10 64bit enterprise.
Now I recently sent my GPU back for an RMA as it wasn't working properly lots of artifacts low clock mem speeds etc so upon receiving my new one I'm still having the same kind if problems.
Gpu usage in unigine heaven benchmark is 95-100% mem is 3506mhz gpu clock is 1316mhz but my Tdp is 40-50% meaning I'm getting next to no performance at all!
15-30 fps when realistically I should be maxing out close to 100fps+
This is all at 1080p.
It's the same with playing games. fallout 4, mgsV, witcher 2/3.
Now I've obviously I've changed the GPU, all the drivers are up to date.
Tried reseating countless times, unplugged and re plugged all cables.
Have yet tried my old gigabyte z97 mobo to see if it's the motherboard, but now I'm starting to think it's my psu?!
I need some serious help as I'm at the end of all the stuff I know!
If you've narrowed it down and found out that the mobo and GFX card isnt the problem, you can now look at other components.
It could be your PSU; maybe a fault with the pci-e cable from the PSU? What about software? BIOS updated or drivers?
Try to think simple.
Cheers for reply, I haven't tried my other motherboard yet need to find some time to do it! All drivers and bios are up to date, changed pcie cable aswell tried all 3 pcie 3.0 slots still the same problem
It's pretty weird as I never had an issue with my amd 270 and a cheap 450w psu! Since upgrading the mobo and gpu I've had nothing but problems
So I had a few minutes to take alook in the BIOS and tried the Asus overclocking software just to see if it would work as before I was getting vga red led when I tried with my other defective 980ti, now it's strange as it's ocd it's self to 4.3ghz, temps are fine and the 980ti has now started to work in the second pcie slot?! Full TDP, gpu usage 100% clocks and mem all fine could the fact my i5 is at stock cause a bottle neck on the 980ti???
Cheers guys
I would check the TPU + EPU dip switches on the mobo to make you haven't accidentally put it into power saving mode. Also if you using Asus AISuite in windows it sometimes likes to change itself from Auto/High Performance to Power Saving Mode which would explain the low fps at stock, happens about 1 a month on my Asus Z77 mobo and my neighbours Asus Z97 mobo to. When you overclocked it to 4.3 it overrides all the EPU/TPU settings and puts it into Max Performance mode automatically.
Are you on latest mobo bios? Have you got any other pcie power cables to try? Does your powersupply have one rail or multiple rails? If multiple try using a cable from two different rails to power cards.
Cheers guys
Your i5 at stock wouldn't cause such a huge performance issue.
Could be a faulty PCI-E lane possibly or maybe it's stuck at x1 speed or something.
Tried flashing the mobo with an updated bios ?
Cheers for the advice guys, I had checked and made sure that epu and tpu weren't on, I do think the top pcie slot is defective but still wouldn't explain why my 980ti is only getting 20fps in unigine heaven bench. It will only work if my Cpu is overclocked? I did update to the latest bios 2501 but I believe they have bought out a new one since then so will give that a try once I finish my nightshifts!
Still need to try my other motherboard, and maybe see if I can check my other stuff out in my friends pc of around the same spec.
